after rebuild 1995 200 txrt: cannot identify part numbers for all (12?) bolts, studs and nuts that attach crankcase. only three (out of six) long side bolts reusable, rest were snapped and junked. please advice part numbers for ordering. thank you
installing powerhead
I am guessing that it is item 13 in this illustration
1995 200TXRT Yamaha Outboard CYLINDER CRANKCASE Diagram and Parts
One illustration shows two nuts and the other shows two studs.
if you said that it is, so be it, however placement of them in crank shaft cover instead of crank case body somewhat strange. ordering. thank you.
Strange to me also. I am just guessing by the way. Yam does not show their data very clearly. Leaves one hanging some times.
ÂÂÂÂÂÂÂÂÂ
