Motor was running great. Went from one fishing spot to another, and then another, and then it just wouldn't fire. I thought it might be the "kill switch" and cut the white wire to that, still won't fire. No pinched hoses, fuel filter is clean, primer ball pumps up, 1/4 tank of gas, just recently had entire fuel system cleaned out and internal filter replace. Spark plugs recently replaced. Scratching my head.
F115 four stroke cranks, but won't fire
I don't know the answer to this, but I'll ask anyways... when the kill switch is in the run position, is it "open" or "closed"? Meaning, if it's "closed" when in the run position (which for some reason, is what I thought it was?), then cutting the wire is the same thing as having the kill switch in the "off" position. Again, I'm not positive one way or the other, just asking!2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostI don't know the answer to this, but I'll ask anyways... when the kill switch is in the run position, is it "open" or "closed"?
specifically the white wire of the main 10-pin harness is grounded to stop the engine
either by the keyswitch or the kill switch, as they are in parallel
so "cutting a wire" could eliminate a defective (closed when it should be open) kill switch
Yamaha uses "close to kill" -
so "cutting a wire" could eliminate a defective (closed when it should be open) kill switch2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by dark_star View Postquestion, why cut the wire rather than unclipping the lanyard clip from the remote box ?Last edited by DennisG01; 06-21-2018, 07:40 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I took it to a marine mechanic. They called and said I needed a new VST pump, ...$1100. I had just had it in two months ago to a different mechanic, and they cleaned injectors, changed VST filter, scrubbed the fuel tank, and changed all the fuel filters, and primer bulb. There was some brown deposits in the fuel system. I"m trying to determine if something may have happened to the pump during this work? I have requested the new mechanic to write it up so I can call the first one and see what they say about lit. Seems like a heck of a coincidence.
ÂÂÂÂÂ
