Where in the heck do folks come up with their information? Why is it so prevalent over on THT?
"Generally if the key switch gets stuck (in the start position) the starter will stay engaged until you put the motor in gear then the in gear kill switch will shut it down. Then when you shift back to neutral the starter reengages. Just check to assure the switch is not sticking in the start position."
