Hi All. I am having difficulty with identifying the year of my outboard. It is a 2-stroke 115 HP unit. Although I found tables with identification letters and numbers, I could not associate with the model number. I am attaching a picture of the engine details plate (The blanked out number to the left is a 6). So from what I can understand, the bottom left ID (6E5) is the parts code, the centre "L" means long shaft and the right hand number (306273) is the serial number. What remains is the engine code - 115AET. The 115 surely stands for the engine power, but the AET, I cannot decipher. From another thread, I was able to identify that the E stands for Electric start and the T is for power trim and Tilt. Somebody also indicated that the A stands for the generation, but still not able to conclude on the year of manufacture. Can somebody please help? Thanks
Engine Model year
It is a model 115AET. Just like the data plate says. Primary ID is 6E5L 306273.
The month and year of manufacture is on a label on the other side of the motor.
http://www.boats.com/reviews/outboar...rt-model-year/
The model is decoded as follows. Just like you mention.
https://www.yamaha-motor.eu/uk/infor...del-codes.aspx
Boscoe99, thanks for the replies, unfortunately there was no plate on the other side. As you can see from the plate with the serial number on it, I was barely lucky to have that as it was half eaten too. Anyway thanks for providing me with the YOM, might I ask how were you able to obtain that just in case I need it for the future? Thanks once again
It comes from Top Secret Yamaha data. If I shared it with you I would then have to kill you. You don't have the necessary clearances. People have reported you as being a "suspicious character".
The year of manufacture of your motor is not going to change in the future.
Are you in the USA? The USA equivalent is a 115ETLG. https://www.boats.net/catalog/yamaha...r/1988/115etlg
Originally posted by boscoe99 View PostIt comes from Top Secret Yamaha data. If I shared it with you I would then have to kill you. You don't have the necessary clearances. People have reported you as being a "suspicious character".
Exactly. I was just joking. My dry humor does not go over so well.
The document I have shows nothing but engine serial numbers based on years of production. It is of value to only maybe one in 100,000. Maybe one in a million.
Just like you can call Yamaha for help you can ask here for help. Any time it is needed.
You are a good man. Apologies are hard to do.
And I apologize for offending you in the first place, even though that was not my intent.
Reviving old thread, can anyone tell me what year my 100HP 4 stroke is? Serial number 67FL311206. Sticker is almost gone so I can't read the 1 letter code that shows year model. Thank you.
ÂÂÂÂÂÂ
