I am a long time reader and first time poster.
I have a 2002 Mercury 115 four stroke and I am having an issue with stalling when giving it some fuel. I have the Yamaha YDS system and have been using that often. It will run at all RPM ranges without spitting at all when I get it there. If I bump the gas fast it will not stall. If I slowly get the rpms up it stalls often. The fuel system has been cleaned (VST, VST Filter, Injectors, etc.) New spark plugs and firing on all 4 cylinders.
I have looked at the voltage on the TPS with the YDS and with the engine off the values range from 0.7 (throttle closed)- 3.9 (throttle open all the way).
I do not know much about setting the TPS or anything about the ISC. I know there are a few setting on the YDS about the ISC but I am a little lost with that. Is that the thing located above the VST tank with hoses coming off of it or is it somewhere else?
Any ideas would be great. Engine is serviced and I am very mechanically inclined but always learning. Below is a copy of my data logger. Thanks, Matt
Save date February 26 2014
ECM No.: 68V8591A10
Diagnosis
Code Item Result Condition
13 Pulser coil Normal
15 Water temp sensor Normal
17 Knock sensor Normal
18 Throttle position sensor Normal
19 Battery voltage Normal
23 Intake temp sensor Normal
28 Shift position switch Normal
29 Intake press sensor Normal
37 Intake air passage Normal
44 Engine stop lanyard switch Off
49 Over cooling Normal
Diagnosis Record
Total hours of operation 210
Code Item Occurred
Diagnosis Record is unavailable.
Engine Monitor
Monitor Item Result Unit
Engine speed 0 r/min
Intake pressure 98.55 kPa
Intake pressure 29.17 inHg
Atmospheric pressure 985.5 hPa
Atmospheric pressure 29.2 inHg
Ignition timing - deg
Battery voltage (12-16) 12.2 V
TPS voltage (0.5-4.5) 0.699 V
Throttle valve opening (0-90) 0 deg
ISC valve opening 65 %
Fuel injection duration 0 ms
Water temperature (below 90) 21 °C
Water temperature (below 194) 69.8 °F
Intake temperature (below 70) 21 °C
Intake temperature (below 158) 69.8 °F
Engine stop lanyard switch OFF
Shift position switch ON
Oil press switch ON
Dual engine system switch OFF
Data Logger[Engine operating hours according to engine speed]
Engine speed Time[h]
- 1000 r/min 13.8
1000 - 2000 r/min 13.7
2000 - 3000 r/min 6.7
3000 - 4000 r/min 40.4
4000 - 5000 r/min 40.1
5000 - 6000 r/min 4.1
6000 - 7000 r/min 0.1
Engine hours 210
Data Logger[Data comparison graph]
Engine speed[r/min] Battery voltage (12-16)[V] TPS voltage (0.5-4.5)[V] Water temperature (below 90)[°C] Intake pressure[kPa] Oil press switch[0:OFF 1:ON]
950 14.72 0.72 22 44.4 0
950 14.79 0.72 22.4 45.9 0
900 14.58 0.72 31.2 53.8 1
900 14.65 0.72 32.9 52.8 1
800 14.58 0.72 33.7 48.4 1
850 14.36 0.72 34.6 46.9 1
900 13.92 0.7 25.4 50.8 0
850 14.36 0.7 28 47.4 0
850 14.06 0.7 30 47.9 0
3800 14.36 0.94 30.8 55.3 0
800 14.58 0.7 31.2 45.4 0
800 14.65 0.7 31.2 45.4 0
800 14.58 0.7 28 46.4 0
ECM No.: 68V8591A10
Diagnosis
Diagnosis Record
Code Item Occurred
Engine Monitor
Oil press switch ON
- 1000 r/min 13.8
Engine hours 210
