My 2004 F50TLRC is very hard to start due to what appears to be fuel problem. I have had 2 starter relays go bad trying to get the motor to run. Anyone else had this problem and if so, any advice?
Come to find out my 2nd starter relay didn't go out and I am back trying to solve the fuel problem. I have to "pump" the idle arm up and down on the controls to get the engine to fire. It will run for a couple of seconds and then die. Prime start problem? Fuel pump problem? Both??
I changed the fuel lines, am using new fuel. Even tried the fuel tank and lines from my little jon boat and it acts the same.
