If cleaning carbs helped. it is a good possibility that it was running too lean and that have cause some pre-ignition/ detonation
Driver For Carb Pilot Plug Screw
During the 2 years I've owned this engine I've replaced the kits twice. This time around I did not replace the kit, even though it's suggested. This was because the gaskets were in great shape, as to were the needles. I hear what you're saying though. But if you did the math using RF regularly per year or even shock treatments, its cost would far surpass the $85 kit per year. Using seafoam might break even. And if I were to pull, replace kit, and reinstall same day....3 hour down time at most. No biggie. Gives me a chance to get my hands dirty...legally that is.Originally posted by TownsendsFJR1300Might want to try it.. It'd be cheaper than all those carb kits and time down...
Just a thought..
I agreeOriginally posted by 99yam40 View PostIf cleaning carbs helped. it is a good possibility that it was running too lean and that have cause some pre-ignition/ detonationJason
