Hello All,
I'm stuck on a water pumping issue. I purchased a 2008 F60 freshwater used engine. The prop seals were leaking oil so I replaced them with success. While the lower unit was down I changed the impeller and the water pumped just fine on the ear muffs out the telltale so I took the boat out and it stopped pumping and overheated within minutes. The pump worked fine initially.
Thanks!
-randyb
I did apply some Super Lube grease in the impeller housing when first changed -- did the impeller fins get distorted or stay too straight because there was Teflon grease applied?
The telltale does not pump anymore and pulses hot air with the muffs. However, the telltale works fine when hooked to engine hose connection. Could I have tightened the prop too tight? I removed the thermostat just to be sure there was no clogs -- everything seemed fine yet I kept the thermostat out for now. Looking for guidance, ideas please assist.Thanks!
-randyb
