The TWO seals where the water tube enters the water pump are both in place?
It is not normal, I have a 89 20hp and no water comes out there.
You should be able just measure from the split line of lower unit/midsection up to bottom of water pipe.
Then measure from mating edge of LU up to WP outlet. Should be able to work out if pipe is going down in the pump.
I do not see how the water pipe would have got pushed up or if that is possible...
