Gday,
I just acquired a 1996 130TLR. The trim is working fine but the tilt not at all. Once it reaches the end of the trim cylinders travel it stops dead, the motor keeps running but it sound like it'll burn out. I've emptied it of fluid and refilled it, I'm sure the fluid level is OK. When I release it with the manual screw I can lift it up and down full travel no problem. Could it be a check valve stuck closed or something like that? Are there any hydraulic schematics somewhere on the interweb?
Dave
Dave
