Port 2006 LF150TXR starts,1200, then kicks down to 700.
Stbd 2005 F150TXRD idling at 1100-1200 rpms.
ISC looks ok. Clicking. Also swapped with port motor. No change.
t-stat not stuck open. Cleaned and tested. ok.
thermo switch had frayed wiring, cleaned and taped. wires could have been crossed at times. tested variations of connected, disconnected and jumped. No change.
cleaned throttle body area. disconnected linkage. everything looks seated correctly.
Noticed fuel rail schrader valve had a slight drip, tighten cap.
I have a multimeter, an older winky blinky (90890-06865) that I used on my 1997 S225V/L225V motors.
I plugged wb into both F150 motors and got nothing. The F150A manual calls for winky blinky diagnostic flash 90890-06873) Is there a way to make this work?
Do I need to get YDS 1.33?
