Ok guys. At idle its at 150 then after about 15 mins at 4200 rpm it starts to climb. Sits at 185 running 45 degree water. If I open it up it will go to 190 with no alarm. The engine has 1400 hours with a new impeller. I scoped the exhaust and it looks ok with minimal corrosion. I have no idea if the stats have been changed of the relief valve. All info came off of my mfd. All is to be changed as soon as the parts arrive.
My question is if the prv is stuck or clogged would that create the high temp? I know the impeller was changed with the kit and they reused the housing.
