I have 2004 Yamaha 115TXRC and when trying to cold start it will not crank, I can pull the manual choke on outboard motor and it starts right up, I can here the solenoid click in operation but seem to not be getting the gas
Auto Choke not working
Originally posted by bigge31566 View PostI have 2004 Yamaha 115TXRC and when trying to cold start it will not crank,
that the starter motor is running thereby spinning the engine
so is that what you mean? that the starter motor is not working?
or do you mean that the engine will not start ?
Sorry for the delay, I had a chance to check the choke today, choke was not engaging only able to get it to work a couple times, removed solenoid and wired straight from battery and it closes every time, put a test on wires coming from switch key and it lights up every time, reinstalled solenoid and barely works if any, put test between wire to solenoid and lights up but solenoid still doesn't engage, dont if im getting full power to solenoid,
Originally posted by bigge31566 View PostSorry for the delay, I had a chance to check the choke today, choke was not engaging only able to get it to work a couple times, removed solenoid and wired straight from battery and it closes every time, put a test on wires coming from switch key and it lights up every time, reinstalled solenoid and barely works if any, put test between wire to solenoid and lights up but solenoid still doesn't engage, dont if im getting full power to solenoid,
Â
