1988 6sg 2 stroke power upgrade
  • 1988 6sg 2 stroke power upgrade
    Does anyone know if this model can be upgraded to the 8hp 8sg with a carb change? Or if it would require more parts? Or if it is even possible or worth it at all.
    Thanks in advance.
    Post the motor code: 3 characters which 6 is the 1st character and S/N.
    Than I may have a look
      It is 6H6 015654
      Thank you for you time.
        That model was manufactured until 1989, in fact your motor was manufactured in 1988.
        I gave a look to the parts manual and at 1st sight found 2 diferences.
        1 your main jet must be an #80 and for 8hp is a #98 (676-14943-26)
        2 the main noozle may be diferent but not sure.
        If you want to go ahead with this mod (at your own risk, I don´t think that may damage your motor but I can't say that you'll see an improvement) however by the price of the main jet (around $10) in my opinion I would try it.
        If you´ll go ahead with this don´t expect a big improvement and the best way to probe it is with a tach.
        Just you can decide what to do...
        In case you'll go ahead than let us know the results.
        Good luck
          Thank you so much for the info. I was told by a dealer that the "tuner" is different also. He said that was what the exhaust was called. Do you happen to see a difference there? I'm a tinkerer so I might give it a shot. So you don't think going from 6hp to 8hp will yield much of a difference in feel or speed?
            Didn´t found any diference in the exaust...
            Best way to monitor the results is with a tach (tiny, small, chinese inductive tach to keep it cheap)
            If improves something is just 2 HP but yes, can make some diference depending the hull, prop and load on board
