Originally posted by boscoe99
View Post
changing vx225 midsection from 30inch to 20 inch
Originally posted by rodbolt17 View PostI don't know what shipping and taxes would be but usually places like Outboard Recycling or sunset marine sell complete mid sections for about 1000 dollars.
takes about 3 hours to change the drive shaft and shim the pinion.
if all your doing is changing the shaft the only special tooling nessasary is dissasemmbling the prop shaft bearing carrier.
on the 3.1L L case special tooling is a MUST.
as is a service manual.
myself I typically check the fwd gear lash BEFORE disassembling.
then simply shim the new shaft until the lash is back to the PRE RECORDED lash.
this keeps the wear pattern on the fwd gear and pinion in the same spot.
just remember on an L case the aft gear is the fwd gear.
occasionally they are reffered to as the front and rear gear.Last edited by roccochiodo; 01-16-2014, 10:08 AM.
this is the midsection I have been looking at on ebay its a 3.1L 200 HP vmax midsection complete with shift shaft... http://i.ebayimg.com/t/Yamaha-VX-3-1...zv!~~60_12.JPGLast edited by roccochiodo; 01-16-2014, 10:34 AM.
I have thought about that.. I remember lifting the motor up with the engine crane to level that my perfectly heighted 20inch leg 140hp is tuned for outmost performance and that made the 225 stupidly high on the boat... it not only looked stupid but I dought the transome would take it very long at that height
ÂÂÂÂÂÂÂÂÂÂ
