It's not about drag racing for me. When you have 7-9 people on board and a bunch of gear, it would be nice to get on plane a little quicker. More efficient. It also would be nice to cruise at a little lower rpm. I'm convinced my boat would be perfect with a V-6. These new, lightweight Mercury 4 strokes may be the ticket. I have no interest in 2 strokes.
Was watching Ship Shape TV....
A lot has to do with flatter torque curves of 2 strokes. 4 cyl 4 strokes are similar to Honda 4cyl car engines. Not much torque until 4000.
V6 or straight 6 4 strokes....now we are talking decent torque.
So what if a motor has *** hp at 6000 rpm. I want to know what it has at 3500-4500 where you cruise.
Too bad manufacturers of outboards don't list torque specs!
20ft
You know how wives are. Invite the neighborhood to go to the beach.....
Ok I was just thinking we usually had maybe 5 people on some 30 and 40 foot boats when fishing off shore in the GOM
But there are times when it looks, I'm sure, like a refugee boat crossing from Cuba.
Originally posted by BQUICK View PostA lot has to do with flatter torque curves of 2 strokes. 4 cyl 4 strokes are similar to Honda 4cyl car engines. Not much torque until 4000.
That would tell the tale....
It's kind of like if you have a 4 cyl car with say 200hp and put 4 fat people in it and it's a slug. But that same car with a torquey V6 with same hp but a lot more torque and at lower rpm and it still pulls.
So it is also evident that appropriate propulsion via the propeller is equally important, they both (rpm power and prop) have to match the boat load at the planing speed.
There were/are some variable pitch props but if they could make a 2 speed gear case or a mini torque converter that would help a lot but the lower unit would be too big most likely.
New cars have more and more gears due in part to low torque high hp motors. There are 8, 9 and 10 speed transmissions ...in cars now. Crazy....
Originally posted by BQUICK View PostThere were/are some variable pitch props but if they could make a 2 speed gear case or a mini torque converter that would help a lot but the lower unit would be too big most likely.
New cars have more and more gears due in part to low torque high hp motors. There are 8, 9 and 10 speed transmissions ...in cars now. Crazy....Last edited by zenoahphobic; 04-03-2018, 06:57 PM.
for 60K$ you could prolly get a gear shift outboard.
outboards are already stupidly expensive.
why not simply prop it correctly for the load and go enjoy?
ÂÂÂÂÂÂ
