About a year ago this same thing happened. Going to make another drift and it doesn’t start just clicks. No turning over. Just hearing it click. Tried it a hundred times. Then all of a sudden the next try it started and worked fine for another week. Then repeated not starting. Researched a little and ended up changing the Starter Relay. Seemed to do the trick. Now a year plus later I seem to be in the same situation.
What would cause this to happen twice? Do you think the relay assy maybe causing this? Should I change them both?
Thank you
Jay
