I am looking to replace the trim cylinder seals on my motors. I was wondering if its sold as a kit or individually . Also opinions on which tool members recommend to remove the caps.
2003 F225 Trim cylinder seal replacement
several variables possible in that model; the SM calls for an install torque of 115 lb-ft for the trim ram caps
(but "only" 65 lb-ft for the tilt ram cap)
and actual removal torque required is a wild card - given the potential for corrosion
when I replaced the trim seals on my F225 TXRD in 2016 -
a homemade (hardwood) spanner worked fine
(although I seriously doubt that I achieved 115 lb-ft on reassembly)
when I later changed the tilt ram seals, I used the Marine Tech tool - a very pretty tool!
I suspect, though, that the best style is the Yamaha tool
https://www.simyamaha.com/Yamaha_Tri...h_p/ytrim2.htm
