Hi All,
I have a 2009 50hp two stroke yamaha with around 20 hours on it. It used to cold start well. However, since a service about 2 months ago, the motor is a pig to start cold. It will either simply start (10% of the time), or will just turn over and over without firing. Once started the motor is a dream and has no problems running or starting. Had to load it up a few times now and its knocking my confidence around with the motor.
Ive had it looked at by someone else and they cant find anything wrong with it. As you would expect, it started for them. The only way i seem to get it going is by turning the emergency enrichment switch to 'off'. Motor then usually starts and after a few seconds will stall. But then i can often put the switch back in the 'normal' position and get the motor going. But this is crazy and i cant do this all the time.
Any ideas people?
Cheers
Tim
Any ideas people?
Cheers
Tim
