I have twin 90s and one of them has started to smoke quite a lot on starting, after a couple of minutes it clears and runs perfectly. They both use the same EXOL oil (TC-W3 spec) that I have been using for years and the other engine only smokes a little at start up as you would expect. I have cleaned the carbs with spray cleaner - done while running by spraying into the air intake which doesn't appear to make any difference. Both engines consume, as far as I can determine, the same amount of 2 stroke oil. Once running at idle both engines are fine, its just purely on starting - anything to be worried about?
2005 90HP 2 stroke smokes on startup
I've got twins as well with one being at lot more of a smoker on start up. It's also the one that drips more oil when tilted so I think it's related to check valve(s) not closing. When it drips into air intake it gets sucked into cabs and goes down crankcase tubes as well.
2 stroke smoke at start up is no biggie, quite typical. Perhaps it's running a little rich though. But what you're doing here ^^^ is a big no no. Not only does carb spray not clean the carbs, but it also eats away at the oil lubing the carbs, so to speak. Carb cleaning entails pulling carbs, opening, removing and clearing jets, checking float height, and replacing kit if need be.Originally posted by CharlieH View PostI have cleaned the carbs with spray cleaner - done while running by spraying into the air intake which doesn't appear to make any difference.Jason
This is also exactly what I have on the smokey engine - how do you inspect the check valves?Originally posted by BQUICK View PostI've got twins as well with one being at lot more of a smoker on start up. It's also the one that drips more oil when tilted so I think it's related to check valve(s) not closing. When it drips into air intake it gets sucked into cabs and goes down crankcase tubes as well.
