Hi and Thanks in advance to any one who can provide me with any help. Here is my situation. About a month ago I was having problems getting the engine started the first time that I would put the boat in the water for the day. After the first start, then it would fire up no problem at the first turn of the key. I figured my carbs were dirty, so I cleanned them and now the engine fires up without problem.
The Engine: 2005 YAMAHA 2 STROKE MODEL 115TLRD
The problem: Now the engine Idles rough in neutral and sputters almost stalling from time to time unless I increase the RPMs. When I put it in gear and increase the throttle, the engine initially responds to the increase in power, but it loses power almost immediately and stalls if I don't reduce the throttle to a no wake speed. Anything over 3,500 RPM will cause this condition. It is almost like if it was not getting enough fuel. The hoses are all clean and intact.
So the only thing that I can think is that I must have done something wrong while reassembling the carbs, but can't figure it out. What did I do wrong? Any advice or technical information will be appreciated.
Once again thanks in advance for any help provided.
. Will get one and see if I can trace the problem while following the instructions this time. If anyone has any other advice I would still like to hear it. Thanks.
