Got a little tilt problem that has turned into a major one.
We had some freezing weather and when I went fishing the motor would not go up. Got it up by bumping the switch. Took it off and opened it up. Electrically it is fine. Took it apart hoping to find some crud under a relief seat. ReAl clean and no blockages. One problem happened which brought me to a screeching halt. The seal relief valves fell out and I can not determine which side was toward the seat. Part # 6H1-4384G-11-00 The parts break out is not very good. Second question is can I change out
The two valve seats with the 2006 and up four stroke . The main body and cylinder casting are identical numbers so if I use the 2006 springs and spacer it look like they should fit in ok. Any ideas
