Hi everyone, I've been following this forum as a ghost for a little while now, but have had this long going issue I was hoping I could get a little help on. A few months ago I purchased a 2007 Yamaha 70TLR outboard from the original owner. When I first got the engine, it ran fine on the muffs at first but then began to run rough. When I would start the engine, it would idle very rough and want to stall out unless I revved the throttle. My friend and I took the boat to the dock and a test run and had the same issue. The engine was idling rough at the dock and wanted to stall. However, once we got it into gear and got it above idle, it began to run great. It ran great all the way up to WOT so we bombed around in it for a bit to just get some gas through it. But when we brought it back down to idle (or tried) it began to get rough and want to stall out again. So we took it home and most of the research I did pointed to dirty carbs. However, I've been doing a lot of research on the PrimeStart enrichment system and began to suspect that as the culprit.
So Saturday, after lots of research on the PrimeStart, we took the boat back to the water. The beginning was the same as the last test ride, it ran rough at first and then cleared up after getting it passed idle in gear. Then is ran great. After running it for a while and burning that extra gas up, we removed the cowling and turned the red PrimeStart valve behind the sound deadener from normal position to totally closed off. I ran it around for another couple minutes and then tried to bring it down to idle again. This time it got down to idle beautifully, both in gear and in neutral. The engine was willing to start and restart freely and was idling great. So (I thought) I had my answer. I went home and took the whole PrimeStart system off yesterday. I bench tested the actual electro thermal valve and it was heating up and moving fine when connected to a battery. As well, the diaphragm and all other internal guts looked clean as a whistle.
Since the PrimeStarter works when hooked up to a battery and everything else is clean in there, is this some kind of electrical problem? Could the PrimeStart be getting no power and therefore just dumping fuel into the engine? I haven't done any cleaning or adjustment to the carbs and nor did the original owner, but it seems odd that that would be an issue since the engine idles beautifully when this PrimeStart system is closed off and very rough when it is in the normal position. Any help or insight would be terrific. Thanks very much in advance.
