Where (how) do I put fluid in tilt & trim?
2002 Yamaha 200 SX
Raise the motor to the full UP position. In between the clamp brackets is the power trim and tilt unit. One side has the electric motor and the other side will have the fluid reservoir. Remove the cap from the reservoir and add as much fluid as it will take. Replace the cap.
Run the motor fully down and then all the way back up. Add more fluid if needed. Repeat the process until there will come a time that no more fluid can be added. You are done.
