two motor elec hookup
  • two motor elec hookup
    can I connect both small wires with red ends to different batteries
    what motors are we discussing (model numbers) and where are the red wires located?
      two motor elec connection
      2000/ox66's, I think the red heat shrink end is the charging wire. located by the battery,on one motor the end has been cut off.
        the Ox66 charges the starting battery Via the battery cable, the other 10Ga lead is for charging a house or auxillary battery.
        the house,battery
        isolator lead, can be taped off,added to the starting battery or taken to an aux battery.
          Thank You RODBOLT17 for clearing that up.
