Although some water has passed in this thread (pun intended), I still have a few points to make.
I'm not overly convinced that the thermostats don't open. The infrared reading is more the outside cover temperature than the inside water temperature. The lower the temperature or the closer we get to ambient outside temperature, the closer to actual "block" temperature it becomes, and not the temperature of the water somewhere behind.
The water flow past the thermostats with engine running on muffs hasn't been measured.
So there are only assumptions not verified.
Salt laden water rises above fresh water. So the theory of it depositing this way has some merit. It wouldn't keep caking up harder and harder, as mentioned earlier, it will cyclically mostly redissolve at every full warm use of the engine.
However that aside the OP is looking for a better flush. In this regard I'm all for some form of a bypass attachment/tube. This drilling of holes in thermostat want produce enough flow without seriously compromising their function. You might as well put in a lower opening temperature thermostat to be more effective. You will need to search for such that have more satisfying opening "curves". The OPs location may warrant such modifications.
I'm very disposed to proven modification solutions to all sorts of design failings, but sadly very little experimentation or mods exist for outboards generally.
