Hi,
I installed a twin yamaha 350, with 25 inch shaft instead of the recommended 30 inch. shaft since no counter rotation are available in 30 inch over here in Dubai (Emirates);
In order to fix them, I positioned the engines a bit distant from the recommended position, as per the wellcraft scarab manufacturer;
Boat performance is fine, its almost same as per the manufacturer performance data sheet; Issue is the planing time ! its taking me over 25 seconds to plane against the 4-5 sec reported by wellcraft; top speed is less by 10% as well as cruising speed;
Question is, do you recommend me to buy and install the Yamaha shaft extention from 25 to 30? Any issue with that?? Easy? Problems? different than originally 30 inch engine??
