Let my boat set in cradle for a year and am trying to get her running.
I have a ton of issues with wiring in the console area... and had that on another thread (deleted) weird stuff... fuel guage out... voltage guage out... tach maxing (during first starting this year)
Had a hard time getting there... but i had her running... ran great... just like a shake down cruise...
next day... no start...
fuel in 85 gallon tank was terrible...put small outboard tank with fresh fuel on deck for testing.
2 gallon oil tank pump failed... removed it and have not reinstalled...oil tank is not connected...
motor tank is full... I get alarm when i pull level sensor out.
i do not believe at all this would be an issue.
had removed one battery and charged it... Pulled the second... and switched batteries
12.4 volts at positive connect at starter.
12.4 volts in fuse box
99yam40 - suggested test at fuel pump... it does have voltage
he said that ECU.. controls negative.
The fuel pump gets 12.4 volts at key on.
All wiring in motor APPEARS to be in just the state it was when new.
I will attach wiring photo... wondering if kill switch has died over 14 years in weather.
i don not HEAR pump... and no voltage across fuel pump motor terms
definitely fuel issue... will kick and run on ether....
what is next in diagnostics?
