View Post
really hard cold start
What's the remedy if that's the case by the way? I'm having the same issue, but I found a start procedure that works, for now at least.
I wonder if you have a bad or sticking float needle valve in one or more of your carbs....not shutting off the fuel and flooding the engine before you try to start it.
Does the primer ball take a long time to get hard?
A little test you can try. Get the thing running, if you can, let it warm up to operating temp. Now shut it down with kill switch. Pinch off the fuel line close to carbs so there can be no more fuel getting to the carbs. Let cool and and try and start again with fuel line still pinched off.....see if it starts any better.
ok.....i got my problem fixed. rookie mistake----i did not remove the metal plate on top of the carburetor and clean under it as my carb breakdown picture looked like there was just a gasket under the metal plate. there are two round disks to remove and under one of them, the one where the carb adjustment screw screws in, there is an area with three tiny holes that needed to be cleaned. once i did that and reassembled it fires right up. Thanks for all the suggestions everyone.
Thanks for the update. Glad you found the problem.
Usually something simple. Simple to fix but hard to find.
Originally posted by boscoe99 View PostThanks for the update. Glad you found the problem.
It is a s/steal plate on top of the carb you have to take off to pull the rubber plugs and s/steal covers off to clean under them.
Anybody got a pic/diagram of this spot he refers to? Will help my ignorant ass and perhaps the next guy as well. Every time I log in I am shown there are over 100 visitors. Only a couple dare post. Why so shy?
good to here you got it taken care of, but it sounds like those were the idle and off idle ports.
I do not see how that would keep the choke from giving enough fuel to fire up
we hear it all of the time that the carbs were cleaned, but it ends up they were not done well enough
Originally posted by 99yam40 View Postgood to here you got it taken care of, but it sounds like those were the idle and off idle ports.
As I said before , it seems that cover dealt with the idle and off idle ports not the main jet where the choke would suck fuel out of for start up,
but then that motor would never have idled properly if those passages under that plate were plugged up
Originally posted by 99yam40 View PostAs I said before , it seems that cover dealt with the idle and off idle ports not the main jet where the choke would suck fuel out of for start up,
ÂÂÂÂÂÂÂÂÂ
