Help
I have a pair of 150 hpdi's with 610 hours and until last week would turn 5700rpms wot
Now the Starboard motor only turns 5000 and the port 5500
The motors run great up to wot and I am missing the 700 rpms on the starbord motor and 200 rpms off port. I assume the 200rpm missing on the port motor is becasue the starboard motor is not putting out full power. I have no bucking, surging shaking or anything else funny going on
All fuel filters changed 6 months ago including the hight pressure pump filters.
Since it was time to change the plugs I replaced all the plugs in both motors (no change in max rpm)
11 out of 12 looked perfect the odd plug was number 3 on the Starboard motor. That plug had perfect burn on 1/2 of the insulator and the other half looked bright white and wet like it had been fuel washed. I am thinking bad coil,plug cap so:
I tested the coil and cap on the #3 cylinder and both are in spec, YDS shows no codes and everything is in spec.
I tested the spark via YDS and it looked the same as the cylinder next to it. I did not use a spark tester I just did a visual look
I swapped the coil and cap from cylinder 1 to 3 and no change cylinder 3 still does not produce power.
I pulled the plug wire from cylinder 3 and the boat ran the same meaning cylinder 3 is my issue.
I tested the injector via YDS and it fired fine.
I pulled the injector on number 3 and had it tested and it was perfect.
Here is the plug from number 3
The other side of the same plug
The other 11 plugs looked like this:
YDS numbers at idle
Monitor Item Result Unit
Engine speed 775 r/min
Fuel pressure (5.0±0.8) 4.99 MPa
Fuel pressure (725±116) 723.82 psi
Atmospheric pressure 997 HPa
Atmospheric pressure 29.5 inHg
Ignition timing BTDC 1 deg
Battery voltage (12-16) 13.99 V
Oxygen sensor voltage (0-1.0) 0.87 V
TPS voltage (0.5-4.5) 0.58 V
Throttle valve opening (0-90) 1.7 deg
Fuel injection duration 1.08 ms
At WOT
Monitor Item (DATA)ResultUnit
Engine speed 4950r/min
Fuel pressure (5.0±0.8 ) 5.26MPa
Fuel pressure (725±116) 768.23psi
Atmospheric pressure 1011.8HPa
Atmospheric pressure 30inHg
Ignition timingBTDC 16deg
Battery voltage (12-16) 13.84V
Oxygen sensor voltage (0-1.0) 0.9
VTPS voltage (0.5-4.5) 4.17V
Throttle valve opening (0-90) 77.1deg
Fuel injection duration 1.48ms
VST fuel pressure at WOT 49 psi steady.
I did notice the port motor idles about 100 rpm less then this motor which seems to show something amiss
ECU maybe? I am at the end of my ability at this point.
YDS numbers at idle
At WOT
