2008 yamaha 115 2 stroke
  • 2008 yamaha 115 2 stroke
    My 2008 runs great but the sparkplug ends keep unscrewing and the plug wires fall off. Has anyone else had this problem? its happen 4 or 5 times in the last 3 years. Can you use locktite on these ?
    I wouldn't use lock tight since it might interfere with the electrical conductivity. You could run a section on mono fishing line through it and the screw it down tight, it kind of makes it a locking nut. Put the plug wires back on and then use zip ties to keep the boots tight around the plugs.
