This is my first winter to store a 2003 Yamaha 40HP four stroke outboard. I've treated the gas with sta-bil and ran the engine for 10 to 15 minutes. Do I disconnect the gas line and run the engine out of gas or store it with the treated gas in it? Any help anyone can give me will be greatly appreciated.
Storing a four stroke outboard
Does running the engine until it stops with the fuel line disconnected drain the carbs or is there something else I need to do?
Yes, you can make a few more things
Read it on wintersize post on top of main page.
Also leave motor stored on vertical position if you can.
Originally posted by Oldjetfisherman#1 View PostDoes running the engine until it stops with the fuel line disconnected drain the carbs or is there something else I need to do?
best to drain them by using the drain screws, but it still leaves fuel in pump and lines
ÂÂÂÂÂÂÂ
