Originally posted by dray0151
View Post
2002 90HP Overheating at low RPM
PROBLEM RESOLVED . Today I worked on the lower unit and water pump. I just got through and sea tested the motor and am happy to report that for the first time in 8 years the problem is resolved. There were two areas where I found an issue. #1 was the original plastic water pump housing was replaced, the old one did not look like it was leaking but it looked pretty old. Second, Part #11 in the parts photo had tons of corrosion underneath. We cleaned that out and replaced all the parts in the kits. Another side issue was that the thermostat had one bolt not tightened to the end- enough that the washer was loose. I suspect that did not help with water pressure, all that being said I was able to go over 1/1 miles at 800 RPM or less and it did not overheat- in fact, the tell tail remains cool to the touch. Photos of everything are included. THANKS FOR YOUR HELPFUL SUGGESTIONS!
IMG_20180125_102139596.jpgIMG_20180125_102134956.jpg IMG_20180125_102841856.jpg
Originally posted by dray0151 View PostBoscoe if your member is that large how do you walk around?
Yes, we need a bilge section. Mary J Bilge we can call it.
[QUOTE=nowakezone;n202000]PROBLEM RESOLVED . Today I worked on the lower unit and water pump. I just got through and sea tested the motor and am happy to report that for the first time in 8 years the problem is resolved. There were two areas where I found an issue. #1 was the original plastic water pump housing was replaced, the old one did not look like it was leaking but it looked pretty old. Second, Part #11 in the parts photo had tons of corrosion underneath. We cleaned that out and replaced all the parts in the kits. Another side issue was that the thermostat had one bolt not tightened to the end- enough that the washer was loose. I suspect that did not help with water pressure, all that being said I was able to go over 1/1 miles at 800 RPM or less and it did not overheat- in fact, the tell tail remains cool to the touch. Photos of everything are included. THANKS FOR YOUR HELPFUL SUGGESTIONS!
Thanks for the feedback. Glad you found the problem.
Originally posted by nowakezone View PostPROBLEM RESOLVED . Today I worked on the lower unit and water pump. I just got through and sea tested the motor and am happy to report that for the first time in 8 years the problem is resolved. There were two areas where I found an issue. #1 was the original plastic water pump housing was replaced, the old one did not look like it was leaking but it looked pretty old. Second, Part #11 in the parts photo had tons of corrosion underneath. We cleaned that out and replaced all the parts in the kits. Another side issue was that the thermostat had one bolt not tightened to the end- enough that the washer was loose. I suspect that did not help with water pressure, all that being said I was able to go over 1/1 miles at 800 RPM or less and it did not overheat- in fact, the tell tail remains cool to the touch. Photos of everything are included. THANKS FOR YOUR HELPFUL SUGGESTIONS!
I hope you replaced both of those pieces.(10 and 11)
without that sealing well will cause exhaust gases to get into the water stream to the water pump reducing the amount of water getting to the power head at low RPM and maybe high RPM tooLast edited by 99yam40; 01-26-2018, 11:54 AM.
ÂÂÂ
