I have found in the past most yamaha's will over heat if the exaust ports arn't covered with water.
2002 90HP Overheating at low RPM
Originally posted by pstephens46 View PostI don't think water should be coming out of there while running. Wasn't there another OP recently with this observation? There may be a problem where the tube connects to the pump. The rubber grommet/seal. Now that I look again, seems to be more 2 stroke oil than what might be "normal" in the first pic.
Turned out the seal was missing (I believe) at the top of the water tube (as I re-call, closer to the powerhead)..Scott
Originally posted by pstephens46 View PostWhat do the two stroke guys think about the oil? Different issue?
Sounds like a small oil leak somewhere finally made it south...Scott
Thanks Scott...I do not know what I am doing wrong wit the pictures...will figure that out later.
I wanted to tell the OP to look at items #1,2,3,4,14, 15 11 and 10. Make sure all are there.
Originally posted by panasonic View PostThanks Scott...I do not know what I am doing wrong wit the pictures...will figure that out later.
No problem...
I simply go to the parts site, "snip" the pic.
Then upload to Postimage, (size 19" screen). Copy and paste "the link for forums"Scott
go hunt another wabbit or chase a different ghostie. water coming out at that point in the pic is normal.
do make sure that all the water tube seals are in place and the housing has ZERO melt damage.
Originally posted by rodbolt17 View Postgo hunt another wabbit or chase a different ghostie. water coming out at that point in the pic is normal.
Thanks, folks, yes I have not pulled the lower unit. I am waiting on the housing - impeller parts to arrive. I did spill some oil when refilling more than once so the oil could be that issue. Good to know that water out of that point is normal.
Originally posted by panasonic View PostWhy are my pics so small???????^&&*%$%^$#^&^
Boscoe if your member is that large how do you walk around?Dennis
ÂÂÂÂÂÂÂÂ
