Does anyone know how I can test the stator? My engine(Yamaha 40 HP ) quit running yesterday. I blew the fuse and the Regulator-Rectifier started smoking. I need to know if the stator is gone also. I have no power to the tilt unless I replace the fuse before it blows.
Testing the stator
When you refer to the stator are you talking about testing the lighting coil that provides electrical power to the rectifier/regulator?
You will disconnect the lighting coil from the rectifier/regulator. Then, with the motor running, measure the AC voltage from the lighting coil. Minimum values are as follows:
9.0 volts during cranking
25.0 volts at 1500 RPM
25.0 volts at 3500 RPM
This is for a 40TLRD. You did not provide the precise model identity. All 40HP two strokes may not be alike.
Well, now that we know that it is a four stroke F40, what is the model? There are carbureted F40's and fuel injected F40's. Carbureted F40A's and F40B's.
What do you mean by "engine" coil? On an F40 there are ignition coils, a lighting coil, a pulsar coil and a charge coil
The only coil that is directly related to the rectifier/regulator is the lighting coil.
If the rectifier/regulator was smoking, and if it blows the fuse when connected, but does not blow the fuse when disconnected, don't you think the problem is more than likely the rectifier/regulator and not a coil?
Whatever coil it is that you want to check, there are procedures in the applicable service manual for doing so.
ÂÂ
