What is pstephens46 going to be doing about it?
Savannah River Bridge Problem
Something stupid for stupid people to piss and moan about. Change the name, pat yourself on the back. Will do absolutely nothing to help the retards who voted for you. Typical liberal BS. Good intentions are measured. Results are not.
Since when is it wrong to refer to countries as shtholes? Some countries are shtholes. Shall we name them? Can we call Detroit a shthole?
Thanks for ruining my day.
[QUOTE=pstephens46;n201372]Why do bridges have names? Will they suffer from a lack of identity?
Most importantly, what should I grill tonight?[/QUOTE]
What time should I be over?
Regarding naming stuff, what a waste of time and money. Intersections, roads, bridges, off ramps, you name it. Got to be named for some mucky mucky with large signs proclaiming about it.
Let's not forget the number one namer. The atlanta airport. Excuse me. The William B. Hartsfield/Maynard L. Jackson Atlanta International Airport. All of the news agencies here were instructed to use the full name. Slip up and say the Atlanta airport and you might be excused. Leave out the Maynard Jackson name and all hell will break out. Don't forget that the new international terminal is really the Maynard L. Jackson International Terminal. They could not get the airport named solely for him so he shares the airport name and got the terminal name for himself.
Oh, the airport is on Candler field. Gotta name that as well.
Has the tachometer been connected to the motor using the trim/oil harness?
If so, check the trim sender to make sure the trim cam is not broken and that the sender is actually moving as the engine moves.
Tachometer settings follow
ÂÂÂ
