2001 F115 Digital Tach Oil Indicator Flashing
  • 2001 F115 Digital Tach Oil Indicator Flashing
    I just replaced the tachometers on twin 2001 F115s due to faded LEDs. The low oil pressure indicators on both of the new gauges are flashing. Is there something on the gauges that needs to be reset
    Thanks for any advice, I am new to this.
    Make sure the DIP switches on the back are set in the correct positons for your motors. There should have been a tag on the tachs with the info you need.
      New tachometers or used? If new they should have come with a tag that indicates the dip switch settings. Do you have the tag?
        Thanks, yes I have the tags. I'll take a look at the settings and what the proper settings are for my F115s. I did not change them from the defaults when I installed them. Thanks for the advice.
          when all else fails, then read the instructions
