Originally posted by pstephens46
View Post
F90 stuck anode
The anode on the side at the bottom had very little salt deposit so I have not pulled the exhaust cover. You also suggested I pull the t stat. That sounds like a good next step. I did run some stiff wire down through the water jacket and taped some tubing to my shop vac and pushed that in as far as it would fit. Looking in with a small inspection mirror I got the salt all out of the head area.
I am not familiar with a citric acid flush. The other I guess would be crc salt terminator . I have used muriatic acid in the past on my old Chris Craft manifolds. Do the products like salt terminator really work?Originally posted by TownsendsFJR1300 View Post
To add to the above, you may want to at LEAST do a citric acid flush or rydlem flush.
Usually, the lower cylinder water jacket and head are blocked up the worst(over time, use, heat from the engine cooks the salt to the innerds of the block, especially when turned off)..
You can get yourself one of these borescopes for less than $100 Great thing for looking in your engine water passages.
https://www.amazon.ca/dp/B076ZGRWKF/..._-ixvAbQ2TV3W6
Better than tearing everything apart and breaking a bunch of bolts off...
I did a search here (and with the NEW site), could not find it. Perhaps someone else has the link.Originally posted by haybailkiller View Post
In any case, it's basically lemon powder mixed with water then pumped thru the engine. Some take off the LU, hook up a small electric pump hook to the water intake tube.
Then put a "catch container" under the engine, thermostat out, and let it pump away. Previous pictures of the results were very impressive.
Rodbolt (MT here), posted here as well it was used in navy.
An interesting video / post with pic's:
http://www.marineengine.com/boat-for...th-Citric-Acid
https://www.youtube.com/watch?v=8w_o5xB8ZFI
This is upper anode hole. Mostly salt with some corrosion. resizesalt.jpgOriginally posted by 99yam40 View PostSearch for rydlym marine descaler,
read good things about it.
not sure what you are seeing in your motor is just salt
I use to race champ karts ,which is a racing kart with a roll cage, and most tracks used hay bails to stop you when you were spun out or spun on your own. One track I went to the drivers were not kind to non local drivers and I got to meet several hay bails up close and personal. My son said , man you killing the hay bails ! So it stuck as my screen name on any forum I use.Originally posted by pstephens46 View PostWhat is a haybailkiller?
resize2.jpgI pulled that today and cleaned block. The t stat is stuck open but blocked and will be replaced.Originally posted by pstephens46 View PostHave you also removed and inspected the thermostat?Last edited by haybailkiller; 01-10-2018, 09:18 PM.
Man, that looks like a blast! Wish I had done some of that when I was younger. Didn't Yamaha build some carts or engines at one time?Originally posted by haybailkiller View Post
There is no jacket to be removed my boy! No cylinder head cover. The head would have to come off.Originally posted by pstephens46 View PostIf you you were able to get that much out of the anode "holes" do you think you may need to go deeper? Remove the jacket and inspect? Broken bolts are a valid concern...
Then the argument(s) can ensue about whether the head bolts are to be scrapped or retained for reuse.
ÂÂÂ
