We sure are busy here at this forum
  • We sure are busy here at this forum
    When compared to the others.
    Maybe that's because we get along better when asking and responding to questions and people aren't afraid to speak up.
    Then too we have the ever extraneous post we all love to do.
    Dennis
      Maybe our engines break more often?
        You may be right about that, I don't know. But it seems to me that a lot of posts here are for older engines, thus more maintenance to be done. I see a lot of engines that are used by commercial fishermen and the Yamaha units seem to be the longest lasting of all brands.
          and there are a lot of Yamahas out there
          Panasonic, what are those things in the pic you have by your name?
          riveting tools maybe
            And why are there cleco's by his photo?
            I need to check and see if there is a photo of a nut by rodnuts name.
              Pan needs to remove his location. It is not politically correct.
                Duck Calls
                  Can Pan tell us, from memory (no looking), what size each colour represents?
                    Really don't like the new format, find it problematic. But then, don't like change anyway.
                      Me also. But then once I have gotten used to the new way of doing something, going back in time is a change I don't like.
                        Spring loaded cleco alignment tool/clamp,
                        never seen these or worked with them.
                        kind of like pop rivits,but can easily remove and reuse
                          Ding, Ding, Ding...Yam wins the contest. They are Cleco's.
                          Used to hold sheet metal parts together while fitting, drilling holes, countersinking....ect before you do final assembly....namely riveting or other permanent fasteners. They are put in and removed with a special pair of pliers, Cleco pliers, which open and close them against a internal spring.
                          The sizes in the picture are:
                          Silver 3/32"
                          Copper 1/8"
                          Black 5/32"
                          Gold 3/16"
                          There are more colors for different sizes...but those are the most common.
                          When replacing or patching a skin on a aircraft there could be hundreds of those in use. Airplane look like a porcupine. I think the most I have in at once is around 1500.Hard on the hands...
