My 1998 Yamaha 2-Stroke starts easily and will idle and ***** all day long. Under power, it is smooth and strong up to it's maximum 5200 rpm on my 17' Boston Whaler Montauk.
The problem I'm experiencing comes in "slow speed zones", where the motor is running at 1600-1900 rpm.
The motor will never stall but it vibrates excessively and steadily. It feels as if it's running on just one or two cylinders. However, I have systematically removed each spark plug cap while running at these rpm's and each plug wire changed the running dynamics of the motor. In addition, I've run every gas additive through the fuel, changed plugs, thermostats, sprayed carb cleaner in the carbs with the motor running and with the motor off.
It has done this since new, and the dealership "rebuilt" the carburetors after about 20 hours. They stated that it must have been bad gas through the motor. My feeling is that they didn't do the work as it did not cure, much less, improve the issue.
My thinking is that the problem is one of two possibilities. 1) The mid-speed throttle linkage needs adjusting, if there is such an adjustment, or 2) The mid speed jets are obstructed, again, if there is such a thing.
Any suggestions?
Any suggestions?
