I removed the engine anode, however only 2/3 of it came out. The anode broke, I can see the other 1/3 but can not reach it. It become corroded on something. What should I do about this?
Engine anode
Not sure... I guess no problem if you old anodes stay inside this block.
I know if this happen on 50hp 2 stroke will block the passage.
Rod or maybe other can make this clear.
Good luck
Originally posted by almetelo View PostNot sure... I guess no problem if you old anodes stay inside this block.
Good luck
I have a 2003 f40 4 stroke outboard! The same thing has happened to me the anode has fallen back into the block! Can you please help me and what should I do? Would appreciate any advice. Thank you.
Bashir
this thread hopping has GOT to STOP.
about the only thing a 60 2 stroke and an F40 share is both have Yamaha silver gray paint.
you really really need to retrieve the broken pieces from the cooling system.
they can and will clog the system.
its also why if your going to mess with engine anodes do it regular and often or not at all.
cant even say both were made by Yamaha, the 03
F40 was a mercury.
ÂÂÂÂÂÂ
