Is the actual shifter shaft long and extend up thru the mid section (just curious)? Any corrosion/ bending?
If you don't have it installed before you read this, try shifting it into forward and turning the driveshaft in the correct direction (do the same for reverse).
Just checking to make sure it is indeed shifting the lower unit and you don't have any damage to the lower unit.
