My motor has been flawless until now. When I go to start the engine cold it will crank over and start at 750 rpm's but quickly stall on low rpms(2-3 seconds). It doesn't seem to want to go into the high speed idle warm cycle. So in order to start it I have to manually put in high neutral using the throttle until it warms up for a couple of minutes. Then the engine runs fine without stalling at idle.
All normal maintenance for the engine has been performed. i.e clean vst, clean 02 sensor, replace fuel pumps, t-stats, etc.
I'm leaning towards a bad sensor - sw, air, etc, but was wondering if the hp fuel pump or resistor may have something to do with the engine not going into a high idle warmup.
Any suggestions would be greatly appreciated.
