Can anyone please tell me where the tilt trim relay is located on an 06 yamaha 200 hp????!!!!! Pleas help!!!'
Tilt trim relay location?
It is at the front of the motor. Down low. Find the power wires that run from outside the motor (from the PTT pump motor) into the lower cowling. They will take you directly to the PTT relay. At the relay there is one sky blue wire (up, towards the sky) and one grass green wire (down, towards the grass). Also, a red power feed wire and a black ground wire.
If it works, activate the cowl mounted trim switch and you should be able to hear the relay clicking.
