V4 100 Yamaha
  • V4 100 Yamaha
    I've just got back from a short trip on my rib which has. V4 100hp Yamaha.
    The engine smoked really badly, and I was advised to give it a clear out. However it didn't clear. On return I noticed it ad used 10 litres of 2 stroke oil to 20 litres of petrol. What would cause this?
    motor tank is overfilling and dumping into intake
    oil pump seal is leaking into crank case
    linkage came loose and is wide open
    (but it should not use that much if linkage came loose)
      Over usage of oil
      Thanks for that. Gives me some things to check out
        Oil usage
        Presumably that would also explain rough running. I reckon it's the oil tank over filling, but why would it do that. Sticky float switch?
          need to find out if that is the problem before troubleshooting it.
