does a 99 200 vmax have a low pressure or low speed fuel pump. could this be causing my motor not to run at low speeds. if I pump the bulb as tight as I can get it the motor will run long enough to build speed and runs fine as long as i'm running mid range.
low pressure fule pump?
its pretty simple.
you have 3 low pressure,about 6 psi, pumps that keep a miniature fuel tank,VST, full of fuel so the electric pump can draw vapor and bubble free fuel from.
this is the HP side that maintains about 35 PSI.
if a lift pump diaphragm ruptures not only will the VST supply be low it feeds raw gasoline with no extra oil into the crankcase.
after spending hours looking for the dip stick to check the bearing grease I finally gave up and took the pumps apart. Those that I paid someone lots of money to replace bout a yr. and half ago. sure nuff the bottom two back diaphrams were split. Thanks. now I know I need to go ahead and replace all three. can I order the whole pumps or each dia. thanks again.
Yamaha 6E5-24410-10-00 FUEL PUMP ASSEMBLY; 6E5244101000; New # 6E5-24410-03-00; Snowmobile Parts
I wonder what make that 6E5-24410-10-00 pump different from the 6E5-24410-03-00 as some sites say they are the same.
Seems the whole pump would cost less than the individual parts depending on what all you buy to repair
do not forget to order the gaskets alsoLast edited by 99yam40; 07-14-2013, 09:21 AM.
