Hi! I have a 2004 Yamaha 200 SW I bought a few months back. I have been having an oil transfer problem since I bought the boat. The engine will run fine for a while and then it loses high rpm because of the low oil level in the eng tank. I can turn switch to on position and manually fill tank with switch on back of motor. This is an occasional issue, once every so many hours after running fine. I do have a blinking icon on the lower part of my tach gauge though. After reading past forums of others whom have had same problem it appears it could be a number of things. I hope someone can advise me on a good starting point to resolve this issue. I dont want to have to pull off my cowling in the middle of a approaching storm or in rough water conditions due to this problem. Thanks and any advice will be appreciated. will be back tomorrow. unowedwho.
Oil transfer problem
