OX66 250 1997 oil control arm linkage.
  • OX66 250 1997 oil control arm linkage.
    On the control arm that attatches to the front of the motor with a joint link to a arm that has two holes in it. Is this part replaceable and if so what is the part name and part # as there seams to be some slop in the shaft arm. I have looked at the parts schematic brakedowns and it is shown but not numbered. I have also seen motors that use the inside hole (mine) and others that use the second hole dose it make much of a difference Is one right or wrong on a OX66 250 1997.
    Thanks Trevor.
    makes a HUGE difference.
    drawback its only listed in a few manuals and I cannot remember.
    however if you follow all the steps in the link and sync section it will ONLY work one way.
      Thanks for the info I will check it out Rodbolt.
      TJ
