YAMAHA 2 stroke 60 hp
  • YAMAHA 2 stroke 60 hp
    what is the correct oil mix for engine after overall .
    *** it is the best forum i know yet
    well done! *****
    Noam N
    chompin,
    Same as recommended by owner's manual for break-in period. If the motor is oil-injected, then mix 50:1 (gas/oil) in fuel tank, and if motor is pre-mix, then double up at 25:1 . Do this for the recommended break-in period, which I think is about 20 hours - check your owner's manual.
    Ken K
      i didn't understand what you maen by pre-mix
      i mix the oil in the fuel tank
      Noam N
        chompin,
        "Pre-mix" models have no oil-injection, and therefore you have to add oil to the fuel tank.
        In your case, you would normally run a 50:1 mixture (gas/oil), but during break-in, you would double up on the oil at 25:1.
        Ken K
          ok !
          this exactly what i did it first and the engine didn't work well on idle but worked silently with higher "rpm"
          than i mix 1/33 and it worked well but a little
          noisy
          thank's for your reply
          Noam N
