Shift Rod
  • Shift Rod
    I have a 2006 Yamaha V-Max 225 HPDI outboard motor. I need to know if I can remove the shift rod without having to take the power head off. Can you please help me?
    Thank You
    first I gotta ask. WHY????
      Shift Rod
      I am having problems with the swivel bracket.
        what issues are you having?
        typically I find a fastener jamming the linkage.
        someone will leave one loose and they find the way fwd and under the linkage.
          I hit a log and now I have a lot of slack in the swivel bracket. I think I have broke something and need to know if I can get the shifter rod out without tearing the whole motor apart.
            removal of the shift shaft requires powerhead removal.
              Shift Rod
              When you pull the carter key out can you remove the bottom bracket?
                no.
                but I suspect me and you are not on the same page.
                post some pictures.
                  What's a "carter key"?
                    It's a "cotter key"...just a spelling error...
                      me thinks you haveth no clueth what your talking about.
                      makes us professional techs a bit leery.
                      that's why I asked for pictures so I can try to figgue out WTF you are doing.
                      the mid section is the entire assy between the powerhead and the gearcase.
                      takes a lot more than a cotter pin to disassemble it.
